Am I good?
Lodgepole
Bought a 21' Lowe aluminum deck boat, Mod 2200 with an OMC 3.0. Prop is aluminum 3 blade 15X17. Runs about 36 with 3 onboard at 4600 rpm. Is this about what I should expect?
steelespike
Re: Am I good?
Seems reasonable to me.How does the overall performance seem to be?
Lodgepole
Re: Am I good?
Comes out of the hole pretty good, but then I haven't pulled a slalom but feel I could pull 2 out with a light load. Wide open RPM is acceptable.
Most charts show a smaller dia prop for this application, but this one came on the boat and seems OK to me.
steelespike
Re: Am I good?
Generally diameter doesn't enter into the selection unless extreme or there is a clearance problem.Diameter simply follows the design.
