BrokeBoatMI
- Oct 3, 2013
- 10
Can anyone tell me wth happened to this gas tank? This off season I decided to remove it smelling strong fumes late in the year. I took it out and it looks like this. I’m planning on replacing with a plastic tank of similar size, but not sure if I’ve fixed the root cause.
I pressure tested the tank using some rubber stoppers and an air gauge; I couldn’t get it to pressure up so I expected to find some holes in the bottom of the tank, but nothing. Also noticed some fuel in the bilge late in the year.
The boat is a 1992 Thompson, so just cutting out a floor area and patching back with the proper plywood and some fiberglass work. The rest of the floor seems to be in very good shape, as was the floor above the tank before I cut it out
