Re: Aluminum dents
My advise would be don't do it, all the banging can losen rivets.
If you really want to yes heat helps, i have heard or people getting the aluminum hot and putting dry ice on it, it causes the metal to contract suddenly and pulls alot of the dent out.
If you use a hammer make sure you have a heavy backer, peice of steel or big hammer and start tapping, you want to work the dent out not take it all in one whack and heating it will help but be careful, to much is bad and too little won't help.
Normally what happens is you end up with a bunch of little dents instead of one big one
