Aluminum Cleaner....Acid Wash ???????
tobym333
Spring is around the corner ....Sweettttt ! . I Traded in my other boat last year for a Harris Floteboat 240 CX. I love that thing... Pontoons are awesome.... however.... I have only had it for one season and the Toons are oxidizing and nearly blackish... I was told to use a product from Napa auto parts store called...." Aluminum Brightner " has anyone had experience with this product and if so what were your results ? Thanks
old jim
Re: Aluminum Cleaner....Acid Wash ???????
That's what I used when we pulled our boat last fall. Works reasonably well but no
polished look. There are outher products if you want shiny bright. old jim
Dont get under or between the logs, that stuff could be dangerous.
rlcrews
not sure about the one you have chosen to use but make sure you read directions .
i tried this and it cost me twice what it should have cost by not reading and assuming i knew what i was doing . after streaking my toons i read the directions and started over with success by applying the cleaner from the bottom , up.
when following the directions i got excellent results with less effort .
Bamaman1
My new pontoon boat started tarnishing the second it was new. My dealer kept it inside a dark warehouse for 6 weeks until I took delivery. By the end of the Summer (3 mos. old), my hull was pretty tarnished.
There is a difference between a tarnished aluminum and dirty aluminum. If you leave a boat in the water all Summer and the toons are green and grundgy, that's when you use an acid based aluminum boat cleaner. It's a spray on, wash off with water product, and it works. But it will leave a very dull finish--no shine.
But if you're just wanting to polish the toons, that's another matter. I researched aluminum polishing closely, and looked at a number of detailing blogs in online websites.
I purchased a Porter Cable 6" Dual Action (D/A) Polisher/Sander with a wool bonnet (applicator). Then, I went to Autozone and bought Mothers Aluminum polish. It was crap. I went to Advance and bought White Diamond Multipurpose Metal Polish and Sealant, the really good stuff.
You put 3 dime size squirts of polish on the bonnet, and put the bonnet on the toon before hitting the switch--polishing a 2' x 2' section. You go up and down, side to side. The liquids will disappear after 90 seconds and the rouge in the polish will work quick--and most of the black aluminum oxide will disappear into the air. You just wipe off the residual black from the toon, and it's polished.
This will give you an almost mirror image, and it's a great look. I could tell you other ways to get a complete mirror image, but such a finish would be impossible to maintain in a marine environment.
You could maintain the shine with Sharkhide, however the oxide has to be completely removed first. I found cleaning the toons with lacquer cleaner is much harder work than I'm willing to do. I'll just polishing the toons yearly with White Diamond. I understand that Sharkhide now has an aluminum polish, and I expect it's a good product.
