Re: Aluminum bottom repair...
I never had any luck with the durafix. The boat acts as a big heat sink and you end up warping the hull. That's not so say someone somewhere hasn't had luck.<br /><br />Also tried Gluv-it. Problem with Gluv-it and all other epoxy products is that they can't deal with the expansion of aluminum. They will give short term relief, but quickly let go. I bouth a gallon of Gluv-it and flowed it on the inside on a hot day, hoping it would find cracks and seal them. It did, briefly.<br /><br /><br />I did have some luck using the green/blue sticks sold through Cabela's and other catalogs. Lightly tighten rivits, cover head with the green/blue stuff.<br /><br />I've read about some folks using the Herculiner truck bed coating from the autoparts store (on outside). I don't see why that wouldn't work, plus adds dent protection. If I'm called upon to make the same reapir again, that's the way I'm going
