Aluminum Boat wiring question
wrfalpacas
Did anyone use the hull as ground when running wires? Or do You run a seperate ground back to the battery for each item. ie: bow light, 1 wire from it or two?
Tacklewasher
Re: Aluminum Boat wiring question
I run a big ground wire from the battery to a junction panel under the dash. I then run a ground from each thing to the junction box.
Don't rely on the hull for a ground, especially in salt water.
109jb
Individual ground wires for everything and also ground the hull. Don't rely on the hull ground for anything though.
Ayuh,... Don't use the hull for the Ground path,... Your hull will Disappear...
