B.E. Anderson
- Aug 17, 2003
- 11
Hello - I have a 12' Quaticha V-bottom aluminum boat - early 60's I believe. It is powered by a 9.9 Mercury Tiller. The aluminum and rivets are sound - no leaks whatsoever. However, the transom is rotten - removed it yesterday. I need to make some modifications to make the boat more comfortable and functionable. I mainly use this boat for river fishing, and it is often necessary to exit the boat and drag it over a sand bar, and at times, carry it a short distance. That, and being that the boat is small, I want to be very careful about adding too much weight.
I have seen many discussions on modifying metal boats, some of the information I can use, but a lot of the modifications are just too heavy. So, here are my questions:
1. The transom that came out was ~ 1 1/4" overall. Looked like a piece of 3/4" and 1/2" plywood. I was thinking of repeating this, but gluing the pieces together and maybe adding some SS fastners. Would that be OK? What about sealing it? I was thinking of a few coats of oil based paint. I can see that the existing transom rotted because of leakage where the fastners that secure it penetrate the boat. These fastners look to be original - pan head, slotted, aluminum? Could I achieve a better seal with nylon washers, and maybe coating the threads with some sort of sealant to protect the wood?
2. Adding a cooler for fish. I don't want the weight of a livewell, and I don't like using a stringer. The fish are dead after a long day, and it's a real hassle and mess to drag them in and out of the boat when moving. I have been using an ice chest, but it takes a large one to hold a 2 man limit of white bass, and there's just no good place anywhere in the boat for it. I was thinking of fabricating a (don't know what to call this) "bulkhead" if you will, the same shape as the vertical upright of the middle bench seat. I know I could do it with wood, but I think one piece of aluminum cut and bent correctly, and then riveted in would work best. This would be mounted in front of the existing bench seat, thus creating a cavity between the front of the existing middle bench seat and the fabricated "bulk head". Of course, since I plan on filling it with ice, I'd have to insulate it somehow. The height of this "bulk head" would be about the same height as the existing center bench seat, and I planned on a hinged / padded lid that would span my new cooler and the middle bench seat, thus creating a larger and more comfortable center seat. I know this adds some weight, but it would be near the center of the boat, and would be much better distributed than one big ice chest. I'd welcome any ideas and / or criticism. And, if you think this is a good idea, I'd need ideas on how to insulate it.
3. Storage in the rear bench seat. I know I can't remove it, but what if I cut a hole in the top large enough to store - say a life vest? I would smooth the edges of course and perhaps cover it with a rubber edge sealer. This would also have a padded / hinged lid - gaining storage and creating comfort.
4. Adding a rear seat. Wrestling that tiller all day from that low, narrow, metal seat just kills my back. I have seen some boat pics on this site that have a seat with a back mounted on the rear bench. I know it would be more comfortable as far as just sitting in it, but does that arrangement allow good comfort and proper control while underway?
If you read this far, THANKS for bearing with me. I would appreciate any and all comments or suggestions.
Thanks,
Brian Anderson
Thanks,
Brian Anderson
