I have a '89 classic deluxe and need to replace the floors. It appears I have to remove the live well to get the floor out. Anyone have any experience along those lines?
Paul
I redid my 1988 V14 Lunker. You have to drill out every rivet in the floor and I had to remove my live well and storage locker. Alumacraft also spot welded the mounting flanges. Go back thru the threads back around the 1st of the year you will find mine, along with pictures. While you have the floor out, inspect and replace wiring , along with doing a leak test.
In my 15 ft Sylvan, the live well was attached to a bracket with a wood strip over the top. I drilled out the rivets holding the wood in place, pulled the wood and then could remove the well from the bracket without drilling out the through hull rivets.
