Hi everyone, this board seems like a good place to get some help.
I have a 14' lund that im doing some work on and when i removed the flotation foam from under the rotton plywood floor i discovered the alum hull has quite a bit of pitting (from salt water being traped under the foam i think), there is only one pin hole but parts are very deeply pitted. what is the best fix for this? jb weld?
thanks for any help in advance
