92 4.3l merc' alpha gen ll
Boat has been out of action for a while as I didnt use it much over the winter and have recently fitted new manifolds, elbows etc and also starter motor.
Since it has been running I noticed that the battery meter was showing between 15-16volts when running and slightly less at idle. I was also getting loads of squealing from the alternator belt. This was also confirmed using a meter on the battery.
Went for a short blast this morning and after a few minutes noticed a real bad smell of burning plastic, I slowed down and checked all around the engine and could find nothing untoward, I carried on back to the marina and noticed there was no noise at all from the belts and the volts were static at 12v regardless of speed. I was fairly sure it was due a new alternator before I went out but was puzzled by this smell, could it be that something had burnt out in the alternator causing this smell ???
