Cricket Too
- May 14, 2003
- 1,732
Just got this '76 Johnson 115 and it has the NGK equivalent of the Champion UL77V in it. I'm gonna replace with Champions but wanted to use something other than the surface gap plugs. I know I can use either QL77JC4 or L77JC4, but just want to know what the difference between the two are, is the QL a little hotter or vice versa? Is there any reason not to put the UL77V's in, I don't particularly like the surface gap, just because I like to set my own gap to .040, but is there any reason these engines use the surface gap plug. Also (and I know I'm gonna get crusified for asking this) is there anything wrong with the NGK plug? I know OMC's are designed for Champion, but the shop I bought the motor from says they only use NGK, and they are a pretty reputable OMC place in the area. Thanks for the info, Mike.
