Salmonseeker
- Jun 11, 2005
- 298
The motor is a 2004 Johnson 50HP, now without discussing the reasons why.
Can someone explain this to me. My motor has an OMS pump, there is also an area where a non-OMS fuel pump could be mounted. It is located near the fuel filter and consists of 2 small tapped holes with a larger hole in the center that has a plug in it.
What is the center hole used for? Is it used to create the vacuum pulses for a different type of pump?
I know the 40HP model of my motor uses a pump at this location but does not use the center hole. Instead it uses the same pulse hole with the pulse limiter fitting that my OMS pump uses.
Is there a reason why OMC does not use this center hole anymore for the vacuum pulses?
Will this hole work with a certain fuel pump?
If so what is the part # for this pump?
Again, I do not want to get into reasons why I need this information.
Thank You in advance,
