Altenator
mike165
What value exciter ressistor do I need to use in place of a lamp?
UncleWillie
Re: Alternator
Re: Alternator
Ohms Law;
R = E^2 / P, Assuming E = 12 volts, E^2 = 144.
Example: P = 50 Watt lamp.
R = 144 / 50 = ~3 Ohms, and at least 100 watt. (BIG Resistor! HOT!!!)
Otherwise, a lot more details will be needed.
Just what are you trying to do?
Replacing a Lamp with an Exciter Resister for an Alternator!!! :confused:
Is this a Small MotorCycle question?
Silvertip
Honorary Supreme Mariner
Re: Altenator
A Delco 10SI takes a 10 ohm resistor. Others will be similar.
UncleWillie
Re: Altenator
Now the Lights come ON! :doh:
The Idiot Light that doubled for the exciter current supply.
