Alpha1-Gen1 water pump impeller relpacement
tbeaze24
What size allen wrench is needed to take off the screw back at the trim tab?
Thanks,
Tim
Don S
Re: Alpha1-Gen1 water pump impeller relpacement
3/8"
crazy charlie
If you are lucky,thats all you will need.I usually have to clamp a locking pliers on to the allen wrench for leverage.Charlie
ManOfwar690
when u replace it use water proof grease on the threds and replace every 2 to 3 years needed or not then u can toss out the visegrips.. btw a box wrench doesnt ruin the tool
crazy charlie
Zincs are not replaced by time intervals.They are replaced by amount consumed.When they are approaching 1/2 comsumption...They need to be changed.Charlie
But if you're Changing your Impeller every Year or 2,....
Like you're Supposed Too,......
You'd Still have it Off,+ should be Greasing it Anyways............d:)
