greekfreek
- Jul 5, 2010
- 145
After installing new impeller assy, Alpha 1 Gen 2, when setting drive housing onto the gear housing, how do i know if the water tube that goes into the upper drive housing is lined up & correctly in the O ring & do I replace that O ring (#88393) also?? Also do I use 2-4-C on impeller blades or liquid soap or else...Thanks again...
