FreeBeeTony
- May 15, 2002
- 3,997
I just seperated the outdrive from my '84 Grady.<br />Was going to replace the impeller and housing.<br /><br />This is the first time for this outdrive for me....just bought it last year.<br /><br />It appears to be an Alpha: flat top and more square on the back of the cavitation plate.<br /><br />When I removed the upper half. I found to my suprise the pre-load pin on the drive shaft. I was under the impression the pre-load pin was only on the pre-Alpha drives. What I did not find was the o-ring near the top of the drive shaft. Not that it was missing.......didn't look as though there is a proove in the shaft for it.<br /><br />Is it possible there was a cross-over in years. I'm pretty sure the Alpha's started in '83 or '84.<br /><br />Also found a large amount of sand in the front near the shift bushing.<br /><br />At least the lube was clean and clear....no water.
