Alpha outdrive hydraulics impact protection question.
Davidius
Hello, I ended up with the pump, rams and lines off of an alpha inboard outdrive I plan to use on a small box scraper I want to build for maintaining my driveway. Is there a way to override or remove the valve that I assume is inside the pump that lets the outdrive pop up if an underwater obsatacle is struck? Thank you.
pull the reservoir off the oildyne 108 pump, the pressure relief settings are under the pump accessible by removing the reservoir.
google parker oildyne 108 pump and you will find the technical manual
Ayuh,.... Welcome Aboard,... There were 3 or 4 trim pumps over the years,...
Which pump ya got,..??
