Ok recently got a boat to waste my money on and going through a few things. Changed water pump in stern drive as other one was not pumping water. New one is not pumping either. I took hose off at inside of hull going to power steering cooler and other end off at thermostat housing assembly. I can run a house through that hose with no blockage. My problem lies in the sterndrive. It is not pumping out water at more then a trickle. This is hose tested and water tested. Hose testing I get a little pressure coming out but that is mostly due to hose pressure itself. Could there be a blockage in a hose in the sterndrive? I am assuming there is cause with a new pump I can't see why lots of water is not flowing. Has anyone had blockage problems in the sterndrive water tubes?
I will be diving into this issue tomorrow afternoon to see if I can figure it out.
Also anyone do freeze plugs on a 5.7 Mercruiser while still in the boat. I do not know it its a back plug or rear side plug, I just know I have alot of water coming out right where my starter is and I found online that there is a freeze plug directly behind the starter so I am assuming that is what is leaking and I really don't want to pull the motor.
Thanks in advance, spent last 2 hours doing online research to help me with there issues.
Joe
Joe
