alpha one water pick up hose
buford123
I have a 1995 bayliner capri 5.0 alpha one. I am having trouble replacing the water pick up hose. Anyone have any suggestions??
Re: alpha one water pick up hose
Ayuh,.... Welcome Aboard,.... What sorta Trouble ya havin',..??
'n,... Which hose, exactly,..??
buford123
Its the hose that runs from the water pick up tube off the impeller pump. It goes up and connects to a plastic tube that runs thru the transom.
Bt Doctur
Once you remove the drive, housing, bellows . Try putting it on boiling/very hot water to soften it some.
buford123
I was wondering if it could be done without removing the drive housing and bellows?
buford123
Can I pull the bell housing and drive off as one unit or would I nned to remove the drive first?
Dshow
Definitely remove the outdrive from the bell housing before removing the bell housing.
buford123
What gaskets and orings would I need? Does anyone have the part number for the hinge pin tool?
Ayuh,.... The hinge pins can be turned with a 1/2" allen key,...
The outdrive gasket set is 18-2619-1 here at iboats,...
If I were you, I'd do All the rubber parts, Now, as the rest are also 'bout done,...
Doin' a new lower shift cable at the same time is another Good idea,...
buford123
All the rubber meaning replace the exhaust bellows? Yes the shift cable is a bit tight. Ahyone have the part number for the lower shift cable?
NHGuy
You'll need the drive bellows, the exhaust bellows, the shift cable and it's bellows, the drive gasket kit, and the hose from the bell housing to the transom. You should also get an alignment bar to check/set the engine position. Try to get a kit with the whole shebang. Could save you a couple of real dollars.
BTW I always suggest a 1/4" flex (springy) extension as an essential tool to snug up the bellows clamps.
buford123
Anyone know where I can find the service manual for this?
sptjet90Reflexx
adult only section has the page for the user manuals.
