The outdrive has two halves, the driveshaft housing (upper) and gear housing (lower). You can separate the two halves and once the lower is off you can remove the upper in any gear.
I'am not replacing the shift cable if I don't have too.how can I move the shifter shoe straight.the cable seems fine?
I believe we force it alittle to much and maybe bent the shifter shoe what can I do
