Alpha one power trim problem
Boogurra
We were to mount our Alpha One drive the other day. When trying to attach the trim-cylinders, one of the pistons was in an extended position making it impossible to attach. We couldn't "push it in". When trying to run the trimcylinders up and down to hopefully move the hydraulics so that it would go in, it went out completely. So now we are standing with the loose piston not knowing what to do.
Any help is appreciated.
Re: Alpha one power trim problem
Ayuh,... Either push it In as the pump is running In,..
Or,..
Take the oil lines off it,+ Push it in....
Don S
Run the trim with the down button till both rams are all the way in.
