- Apr 17, 2002
- 71,413
Re: alpha one no or very very little water exiting through prop or exhaust relief po
Ayuh,.... Have ya put a T-stat into the T-stat housin',..??
It won't flow right, without it...
the problem is boat over heats when on plane or under throttle with a load. cools right back down when idling or putting along at 1000 or so rpm.
what i have noticed so far=
very very little if any water exiting the relief ports or through prop exhaust passage.
replaced the impeller in the out drive. the old impeller had 1 fin left on it. the rest were missing. i found a few small peices in the thermostat housing " there was no thermostat in the housing" pulled hose off the thermostat housing water comes rushing out. pulled the supple line of coming from the lower unit through the transom at the thermostat housing flows lots of water.
removed the manifolds, risers, and elbows - the gaskets from the manifold to the riser had 2 ports and a very small pin hole on the other passages, as apposed to being open.
removed some scale and sand and rust debris from the manifolds and risors, also the same from the block drains on either side of the lower block, poked around with a wire and it poored out with the water in the block.
i am getting water to the thermostat housing.
i do not know if i am getting water flow through the block
i do not know if i am getting water flow through the intake manifold.
i am not getting water flow out the exaust/overboard.
i am getting water flow to the exhaust manifolds.
i am planning on doing some inspecting tomorrow all day. what should i be looking for maybe the water circulating pump on the engine?
my plan is to inspect every hose, and item in the cooling system starting with the water supply on the in side of the transom.
