Alpha one drive issue diagnosis
the man
Re: Alpha one drive issue diagnosis
There are quite a few special tools needed.Some can be made but some need to be bought .
http://www.boatfix.com/merc/Tools/tool1.pdf
new gearset w/ bearings ,seals,O rings $500
water pump kit $60
2 qts of gear oil $XX
Misc $40
NO WARRANTY ________________
$600
Assuming NO damage in the lower unit
SEI 116 3 year Warranty $695.00
I read $1395.00 plus shipping. What am I missing?
http://www.sterndrive.cc/mm5/merchant.mvc?Screen=CTGY&Category_Code=MercruiserAlphaGenIISterndrive
Fishermark
He was quoting the price for just the upper. You can buy either the upper or lower - or the complete unit.
Like was mentioned above, the grit, debris, etc from the upper has at the very least contaminated the lower as well.
It is literally cheaper to buy a new unit than to rebuild yours - since you have to get a specialized set of tools. If you enjoy rebuilding things and learning as you go - then go for it! It may or may not be successful, but if you enjoy it, then the process should be fun and educational.
If however, the main goal is simplicity and dollars and cents and getting back on the water... then you will either need to buy a new outdrive - or take the gamble on a used one.
