alpha leg on 2001 boat goes down will not lift
northertunder
Hi I have an alpha leg on a 2001 bayliner with a 4.3 the leg will go down but will not lift worked good all year put in garage went to winterize boat put leg down will not come up Thanks
zbnutcase
Re: alpha leg on 2001 boat goes down will not lift
Do you hear any clicking (solenoid) noise when trying to lift it?
Kaplooi
This problem is often the trim limit switch wiring fraying and coming apart around the bell housing because as you turn the drive the wires can get pinched between the bell housing and gimbal ring. If this is the case the easy (lazy/cheap) fix is to simply cut the wires in the boat and short them thereby bypassing the switch and your drive will go up fully. The risk is that without the switch nothing will stop the drive from raising to any height when you're trimming in the water so you have to be careful or else catastrophic u-joint failure could occur.
The 'right' way to fix it is to replace the trim limit switch (and adjust it to the trim limit specified in your service manual) and route the new wires through the transom plate. It's basically impossible to do this without at least removing the drive and bell housing. Many people rationalize not replacing it because of the labor involved given it'll just fail again (hopefully after several years) but you take the risk mentioned above when trimming.
northertunder
no clicking just will not move no pump noise or any movement thanks
northertunder
I found the problem on the 2001 Bayliner 185 capri the bimini top stores in the back under the back hatch when we traveled back from the coast about 1000km the bracket for the top knocked a wire off an easy fix thanks for all the Idea's guys
