Oil turns light blue/ milky over several months of 24/7 in water time.Oil does not run out.Have pressure tested right from reservoir,with drive empty of oil,holds 14 pounds forever.Drive is 5 years 500 hours old.
Did not vacuum test as I read somewhere that newer style seals don't hold a vacuum.
I'm reluctant to do a complete drive disassembly at this time,thinking /hoping it's quite likely the seal below water pump. Thoughts or advice wanted.
