Alpha gen 2 water getting in gearoil
telstar1
Oil turns light blue/ milky over several months of 24/7 in water time.Oil does not run out.Have pressure tested right from reservoir,with drive empty of oil,holds 14 pounds forever.Drive is 5 years 500 hours old.
Did not vacuum test as I read somewhere that newer style seals don't hold a vacuum.
I'm reluctant to do a complete drive disassembly at this time,thinking /hoping it's quite likely the seal below water pump. Thoughts or advice wanted.
Ayuh,....... Do you change the drain, 'n fill screw gaskets each time you remove 'em,..??..??
telstar1
Yes .I've been using the ones with green o rings and I believe they are good Wouldn't they leak air or oil out if they were the problem?
Ayuh,..... I donno, I use the black/ gray paper ones, 'n some years back, I had a water problem, that I eventually traced to a burr at that gasket face, which I cleaned up, 'n the problem went away,....
telstar1
I think I'll switch back to those ones.What about the vacuum test Bondo,? Is it something to be tried?
Ayuh,.... The vacuum test is a Volvo thing,....
Merc manuals state the pressure test,.... Which I do, with the drive on the bench,.....
That way, I can rotate the shafts, shifting it, 'n whatnot,....
