alpha gen 2 shift shaft bushing
keijonen123
I ordered quicksilver shift shaft bushinkg kit 23-806036A-1. I only got one seal? is it right? I think I have seen two in pictures. And how about the installation of the seal(s): Which side goes up against bushing? the "open" or "closed" side?
Thanks!
alldodge
Not a Gen 2 expert but hopefully someone will come along. Looking at the manual No 14, it shows only one lip seal and a couple O-rings, then one bushing on top. With all lip type seals, the lip faces the fluid your trying to keep in. In this case the lip (open) faces toward the gear lube
CFM56-7
Aren't you trying to keep water out of the shift cavity? Lips should face down towards the exhaust passage...
I'm doing mine soon. Please correct me if wrong.
