Alpha drive water pump base replacement
crazy charlie
I have a 1988 alpha drive,not a gen 2.I am replacing the water pump and the pump base.I have never done the base before.I pryed it up and off.Looks like there is just a gasket for the base and an oring to go around the round part of the base..Is that all for the base or am I missing something..? Looks too simple.Charlie
matthew colgate
Re: Alpha drive water pump base replacement
Mine is the Alpha One drive also ..... I just did mine also and thats all that was there on mine the gasket and o-ring...... I also thought too simple ......
Don S
There are also 2 seals on the inside that seal on the vertical shaft.
matthew colgate
That's right Don I forgot about those oops still early not enough coffee intake just yet lol
crazy charlie
I will take a close look but should I assume that the new water pump base does not come with the seals on it??
matthew colgate
That I couldnt tell ya for certain as I said I got the whole kit that had impeller pump cover and all gaskets , seals and orings and impeller to do the job
crazy charlie
compared to the base that I removed,the new one (sierra) is exactly the same.Guess it came with the seal..??
Don S
ASSUME NOTHING, Just look at it, the seals are really obvious.
crazy charlie
Thats exactly what it looks like.Thanks for the pic.I was surprised I was able to buy a complete kit for less than $30 charlie
