Alpha 1 gen 2 shift does intensity of ratcheting matter
Stinnett21
After install and adjustment of new lower shift cable:
Forward: Locks CCW, ratchets CW
Neutral: Spins freely both directions
Reverse: Locks CW, ratchets CCW
HOWEVER, it ratchets more intensely (harder more firm ratchet) CCW when in reverse than CW when in forward. Is this a problem? Or as long as it's locking both directions I'm fine? Is there a way to adjust to even out the ratcheting or is it even necessary?
muc
"Retired" Association of Marine Technicians...
Yes, a problem. You missed something.
But you did real good checking like this.
That's how a seasoned tech checks their work.
Should ratchet harder when in forward. About twice as much. No clicking in neutral.
Good information in Section 1C - Troubleshooting, Shift System, Section 2A - Remote Control Shift Cable Adjustment and Section 4A - Alpha Intermediate Shift Cable. Read all 3 and become a master of the intermediate transom cable.
Stinnett21
I have manual 14 and I've read those parts. I also watched Chris' YT video and tried to do exactly as he does. I just don't understand where I'm going wrong.
muc
If you’re sure on the 6”. Adjust the shift cable from the helm to get the ratchet right. Shouldn’t be more than 1/2 way up the slot with a new inner transom cable.
Stinnett21
Great I'll try this. Thanks muc! The boat is 1.5 hours away so I may be a bit.
