tzmanyndvl09
Thread starter- Joined
- Apr 8, 2015
- 14
Hello all, I'm new to iboats,
I was working on an Alpha 1 gen 1 lower unit that I got off craigslist for my boat. the unit was in way better condition then my old one. After I installed it, and ran the motor (with the muffs on, and water was pumping strong) I turned the motor off and went back to look for leaks. I noticed a steady stream of gear oil coming out of the weep hole on the starboard side of the lower unit just above the prop towards the front of the unit. After my research I found that the cause was most likely the shift shaft seal. The prop was off and there was no oil coming from the prop seal. My question is, is the shift shaft seal hard to replace, and if so what all do I need, Tools, Part numbers, etc. (and if anyone knows the parts numbers for the impeller replacement that would be great too i mean im down there anyways might as well change it!)
