alpha 1 Foward no reverse
raceit666
Hi , I have a 4 cyl merc W/ a alph 1 drive its a 1989 ok it was running great last year. i winterized it and put it to sleep...i just started it up and low and behold ....i have no reverse. the shift cable was disconnected from the engine and worked manually it moves freely it also is moving the shiftshaft. it goes right into foward with no problem .when i move it to go into reverse it seems like it isnt going anyfather then netural.the shiftshaft it turning all the way to the right {looking from inside the boat} but not a click nothing no bad noises at all .the manual does not tell me anything about having foward and no reverse ???i am confused help please.......<br /> <br /> Jerry Diperri
crazy charlie
Re: alpha 1 Foward no reverse
Did you remove the drive to winterize or did you leave it on all winter.Charlie
raceit666
it was left on all winter like it has been for the past few years ,,,i was told the drive being removed it for security reasions only.
