Hi, new here to the boat repair scene. I have a 88 merc 4.3 alpha 1 setup with some issues. I was cruising at about 3000 rpm last night when the boat started to vibrate suddenly and slow down at the same time. I put it neutral, then back into gear same problem. Next I turned the engine off and tilted the drive up to check the prop, but it looked ok. I then tried to start the engine but it made whinning noises and wouldn't turn the engine over. To make a long story short, got her home pulled the starter and I can spin the flexplate thing by hand. Never worked on a boat before but I know you shouldn't be able to spin by hand like some bolts broke or came loose. If someone could give me some help on how this drive coupler setup works that would be great!
