Still having a little issue with my motor. Which is an 86 omc 2.5L seadrive. I have worked out the fuel issues and the timing was off. But here is how it sounds now. There is a little studder to it with a noise when it studders.
I listened to the video and it does have a repetitious sound to me, with a type of knock every now and then. I would certainly check the fuel system first. If the float level is off or the fuel pump is questionable it could cause something like that. You could also monitor the spark as well to make sure the ignition isn't missing. JMHO
