wakelessinidaho
- Aug 29, 2022
- 2
Have a nearly new Mercury 20hp EFI 4-stroke outboard and it idles very rough and if left idling will completely shut off. At lower RPMs cruising it "misses" every so often. The lower the RPM the worse it works. Seems to work fine at higher RPMs.
Probably has less than 40 hours of runtime on it, mostly at trolling speeds. Super picky about keeping clean fuel and always use fresh non-ethanol gas.
Bought an expensive EFI 4-stroke so I wouldn't have this problem. Suggestions on troubleshooting? Is this fairly common?
Thanks folks.
Thanks folks.
