almost floated my truck yesterday
soggy_feet
Lake Champlain is well past its flood level right now, which has pretty much shut down half the marinas. The marina I keep my boat at has a couple feet of water in the parkinglot.
Yesterday I needed to unload some extra lumber from the boat, and bring it back to my friends house where Im still wintering. When the 10ft 2x4's went TO the boat, i just drove down into the lot as there was only one small sailboat blocking me in drydock.
Now, to keep my feet dry, I have to zigzag between 6-7 boats and skirt the edge of the lot. Not something I saw myself doing with 10ft boards, and after wading thru part of the lot the other day, I figured it wouldnt be too bad to just drive across in the water.
Well, about 2/3 of the way across, I passed over the area that the storm drain occupies. Otherwise known as the lowest point in the lot. I could feel the water churning under the cab, and the bumper was pushing up a pretty good wave. Annnd my tires started to slip.
Oops!
I gave it a little more gas to keep up momentum, and clawed past that spot to an area with only a couple inches where I could stop and load up.
Getting out was just as stressful, even thought I locked the truck in 4, because I'd normally do a 3 point turn and drive up the hill and out, but to do that I'd have to back into the deep, stop, take the truck from reverse to drive, and then hit the gas again.
Letting off the gas in deep water is NOT a good idea. I ended up backing down the line of boats, and up the driveway, and then backing onto the somewhat busy road.
Added a bit of excitement to my afternoon, and the truck got a good belly washing, but I don't think I'll try that again...
wifisher
Re: almost floated my truck yesterday
Glad you got through it OK. There are a lot of people dealing with too much water this year.
soggy_feet
I should post up some pics. As the water was coming up, I'd take a pic every time I went to the marina to work on the boat. They're on my phone though, and I need to figure out how to get them online from there.
j_martin
Sweep the rubber nickels out of the driver's seat and yer good to go.
royal0014
Master Chief Petty Officer
Does the word 'statistic' ring a bell? You were lucky....:facepalm:
soggy_feet
Statistically what?
Keep those revs up, and lock'er in 4 if she quits movin!
D
DJ
Guest
Now, drain the water out of your differentials.;)
soggy_feet
I like to leave the diff covers loose so they self drain.... ;)
Home Cookin'
same guy who leaves the salt water in the motor so it won't freeze....
