G
Guest
Guest
I was going to install a stock water pressure gauge in my '98 200 Ocean Pro. There is a (steel?) allen head plug on the top of the motor leg on the port side where the power head bolts to the leg. I put an allen socket into this plug and turned it, and the socket just turned within the plug after a moderate amount of grunt.
Yes, I did use the proper socket size, but the plug didn't move. I think this plug has been in the motor since new, because it looks like somebody in Waukegan put it there. I think the socket sides in the plug are now rounded.
I'm a little nervous about dropping the lower cowl off and drilling this out because, we're talking NFPT in an aluminum casting. Boogering this thing up in the slightest way could render the motor un-usable without a dollop of JB Weld, which I do not want to do.
Has anyone here had to fight this kind of critter?
I can put a trim gauge in its place on the panel, but I'd really like to use the water pressure gauge. My Dad had one on his 155 Commercial, and it was great because we could determine when the pump impeller was going bad..
Your thoughts on approaching this challenge are welcome, Gentlemen, Thank you in advance.
