BreakOutAnotherTwenty
- Jul 30, 2011
- 7
I am finishing up my Chaparral 187. I have re-done the decking, carpet, upholstery, etc.
Trying to align my engine (Mercruiser 3.0 engine, 140 sterndrive) and go boating, but no matter what I do, the alignment tool is hard to pull out. I tested it in the spline without the Gimbal bearing, and it was smooth. Also smooth going through just the Gimbal bearing. As I attempt to align them however, I'm stuck.
I whacked all 4 directions on the alignment tool. I started with my front engine mount all the way up and had my son rotate the adjusting nut 180 and I would test. Rotate 180, test... all the way down. Then all the way back up, then all the way back down.
With the engine at the highest and lowest points, the tool doesn't want to go in- but anywhere in between- it is difficult. A few times it has felt like I was making progress, but then when I double check at the same setting, the tool feels stuck again. I feel like the engine is shifting a bit.
The engine is 6 or 7 years old, so I assume the rear engine mounts are that age as well. I can wiggle the engine up and down a bit with a flat screwdriver between the mounting brackets. I'm tempted to replace the rear engine mounts, but I don't really want to spend any more money if it's not necessary.
Thanks for your help. It's almost August, and I'm still not on the water.
