1993 Bayliner 2252 with Mercruiser 5.0 and Alfa 1 replaced from another boat 2 years ago by th seller.
I`ve got a boat for one year and everything was fine. Starts knocks recently and now knocks harder. Didn`t hit anything underwater. When boat on trailer with flusher attached runs fine ahead and revers. Prop turns freely by hand but you can move prop and shaft for about 3 mm back and forward with nand. Too loose?
On the water runs revers fine but knocks forward. No noise like bearing gone. Put wheel hard aboard in revers engaged - no knocks. So U-joint supposed to be OK. Called merc mech, he said possible chip on gear. Thanks Vic
