Alcan I have just one more question
swellcat
In regards to the 1970 Chrysler 3.6 hp 32HA. <br /><br />Ok I got it running and I just have one final question should the "F" knob be in or out to run it or does it matter if anyone knows how these work and what they do I would really appreciate the help Thanks again for all the assistance. Garrett<br />garrettcraen@hotmail.com
seldont
Re: Alcan I have just one more question
If I may, just adjust it for the best idle without bogging down when quickly open the throttle. If it bogs you are too lean. Turning it clockwise should richen and counter clockwise to lean the mixture.
alcan
Hi Swellcat<br />As I do not have a picture of your exact model I do not know how the "F" knob works. I suspect that this model is a single cyl air cooled model. If so it will have cooling fins on the cyl. I also suspect that the "F" knob is the low speed needle adjustment. This controls the air/fuel mix when the throtle is closed. It should work as seldont suggests. You might use this feature to smooth out the idle, as while trolling. This should have no effect on high speed running
The Marine Doctor
The F knob is used to turn the fuel on and off for the engine.<br /><br />TMD
