albertgotch
- Jan 23, 2011
- 2
have a knocking while turning when docking or pick up skier. I replaced one u joint when I replaced the motor. The front joint would hardly move thats the one I replaced. I did not do the other because it moved easy and smooth. Should I replace the other or replace the whole shaft? It looks like the u joint press might not have enough clearance without removing the lock ring.
Thank You for any info Al
