Alarm signal/oil pump by pass
J.A.M.
I have 1990 johnson outboard motor 100 hp.,the water pump has been change out,but the alarm for over heating sounds off. is there a cure for this problem. Also I would like to by pass my oil pump and start to mixing the oil my self. Thanks.J.A.M.
OBJ
Re: Alarm signal/oil pump by pass
JAM....is the engine overheating? If it is and you have replaced the impeller, then a the replacement of the T-stats may be needed. There are two on your engine, one for each head. Do you have a good flow of water from the pee hole on the lower engine pan?<br /><br />There have been several excellent threads on the disconnection of the VRO pump. Do a search for VRO and you should find what you need.
