Boat: 2015 Regal 2100 - weighs about 4,000 pds
Bravo III
Sterndrive
350 MAG MPI
I have an odd thing happening with my boat. About once every time out, my one beep constant alarm goes off. I stop the engine and restart and the alarm doesn't go off again. I have had this happen a dozen times now. All gauges read normal when the alarm goes off (temp, oil pressure, rpms, voltage, etc.)
Most of the time, it is within the first 15 minutes of my initial engine start when this happens, and all but one time it was when I was fully underway at about 20-25 mph. Twice it was when I had a wakeboarder behind the boat (meaning usually it is just when we are heading out for the day when it happens.)
When the alarm fires, the boat decreases in speed. I usually stop the boat immediately and cut it off. Then restart, and all seems to be good. Anybody with any guesses here? Taking it to a mechanic this week, but would like to hear some thoughts that others might have on this. Here are things I have been thinking about:
* Gear lube alarm. This seems like the logical one because I see a lot of things online about this giving false positives because of a stuck float. However, the engine seems to slow when we get the alarm and I believe that doesn't happen for gear lube based on my what I have read online.
* Injector not firing. Perhaps, this is it. The rpms are normal (below 3000), but I am cruising pretty slowly (20-25 mph) when the alarm goes off. Maybe the rpms would stay low on V8 when you are cruising at that speed?
* Some sensor not working properly. Not sure which one, but this seems to be logical as well.
Anyway, any assistance would be appreciated. Thanks.
Bravo III
Sterndrive
350 MAG MPI
