Re: Alarm for water in the bilge...
Something about that doesn't sound right to me. I would assume that the alarm is tied into your float switch for the bilge pump, and that when the switch is activated due to high water level, the alarm goes off at the same time?
What's bothering me is that the float switch is located in the lowest part of the bilge, and passengers moving to one side of the boat should decrease the water level at the bottom of the bilge... the standing water will move off toward the beam. Or is my logic flawed somehow?
In any event, assuming you know you have no leaks, you have options. If there's enough water in the bilge to activate the alarm, you should be able to pump it out to the point where it doesn't sound (though I still don't understand why the float switch didn't do that).
OR, you could move the float UP a half inch, OR put the alarm on a switch you can control from the dash. I don't recommend that solution tho- you could easily forget to reactivate it (just throwing out options to help you think it through).
My .02
