I appreciate any help I have been dealing with this problem for 2 seasons I have replace all fuel lines from tank to engine and checked pick ups and tank and fuel itself was told by local boat mech. that not fuel pump which is fuel/oil pump I also changed to 23 mic. separator which is what manuf. call for I have also run directly from tank in engine to take out everything down line still get up to speed los of power and buzzer so after lot of slamming head I set up appointment at local marina
asked him if he thought it was carbs. he said yes probably he said 1200 to rebuild them so I drop off boat they have for 3 days then find out they cant get bowls anymore so they tell me its not my carbs but I need lower rod cleaned and that is 400 and then after they charge me sea trial for 125 they say I need fuel pump which is just under 600 hundred plus 150 to put in so after I get boat back I take for ride still only at 5100rpm but running without stutter or alarm one first trip out on second trip starts to stutter at full throttle and slight beep of alarm so I look at motor and see that marina did change all fuel lines that came with my 600 fuel pump and I notice one line is not factory but looks kinked a little so I change it with longer one with nice easy curve take out for ride now I am at 7100 rpm no stutter or alarm so I go into ocean on my way back thru inlet at speed got little alarm and slight stutter so now I want to sink the dam thing this motor has high compression and is really good shape only 821 hours on it and properly maintained since I got it 5 yrs ago
