Alarm acting strange
alden135
This has been going on since I bought the boat and would like some ideas.<br /><br />When I first get to the boat and turn the key to choke it, I get the normal alarm test chirp and things start fine.<br /><br />If I have run the engine within a few minutes, to a couple of hours, when I turn the key to "run", I get the constant alarm. I have to turn the key to "off" and then back to "run" and it stops.<br /><br />I have tested the alarm temp sensors and they work normally when I ground the tan wire.<br /><br />Any thoughts?<br /><br />BTW I replaced the switch and it still does it.<br /><br />Thanks,<br />Alden
angus63
Re: Alarm acting strange
If it's a self test horn (sounds like it is), the selftest feature may be faulty. Swapping with another horn will let you know.<br />Good luck
