aircon
pfitz128
I have a sea Ray sundancer 240 the aircon blows only hot air it worked fine last boating season what are the most likely causes and how to fix as well
Bob_VT
Re: aircon
Leak in the coolant????
pfitz128
air con
air con
I have a sea ray 240, 2003 last season the air con worked fine, then I had it winterized, this past weekend I tried turning on the air con, systm came on, and it shows cooling but only warm air is coming out, there is no water flow out the side of the boat, I believe the sea **** may be closed, where is this sea **** located so I can check it out
thanks
Pat
Grand Larsony
Re: air con
Re: air con
Can't comment on exact location of the thru-hull for AC but it should be easy to find.
Even if you do find it's closed, you'll likely need to prime the system. Open strainer, open sea **** until water comes up and out, close strainer, start system and check for outflow. If not, prime further up into things (possibly by shooting a low pressure hose into the outflow thru-hull... but I've never had to do this myself.
And I hope you didn't run it for too long without water !!
