Air Fuel screw setting 3.0 Merc.
mudmagnet63
Where does the A/F screw on the bottom of the carb need to be set?
1989 merc 3.0
JustJason
Re: Air Fuel screw setting 3.0 Merc.
I could explain it but your better off just googling "lean drop" method for adjusting carbs... you should find what you need if you use that term
