Re: "Air Floor" Inflatables?
Thank you for all your input. This is what I am looking for, seat of the pants input as well as actual user likes and dislikes.<br /><br />RotaryRacer,<br /> I have considered the Futura, I like the boat, but it is too heavy for me to carry in by myself. I do need a boat that one person can handle easily.<br /><br />NOSLEEP, The 10ft Zodiac that I have now is rated for 10hp and I'm running A 15hp Evinrude on it (light weight for its HP) with no problems what so ever. <br />The 11ft that I am considering (air floor) is rated for 15hp. An Aquaintance of mine that has a Zodiac identical to mine (10ft), has run an older 20hp Merc on his for several years without incident (just about double the motor weight of mine).<br /><br /> What I am trying do is find out as much about the joys and gripes with air floors from people that have used both equipped with motors that are more than capable of planing them.<br /><br />NOSLEEP, <br /> Is your Zodiac one of the newer ones with the keel attached to the floor? I have noticed that the floor tends to be bowed up over the keel even in the showroom. Does it tend to be worse in operation with loading? You also mentioned that it is difficult to patch the air floor, is this because of the texture of the surface, the pressure used to support the floor, or both? May I ask how the floor got punctured? Could the durability of the floor be a major issue in your opinion? <br /><br />I have had the Zodiac I have now over 10 years, the next one I buy I will probably own the same lenght of time and I'm trying not to buy something that I will be unhappy with in the long term.<br /><br />Cheers<br /><br />Any other input???
