air con
pfitz128
I have a sea ray 240, 2003 last season the air con worked fine, then I had it winterized, this past weekend I tried turning on the air con, systm came on, and it shows cooling but only warm air is coming out, there is no water flow out the side of the boat, I believe the sea **** may be closed, where is this sea **** located so I can check it out
thanks
Pat
