Re: Air circulation effect on resin???
Does air circulation have any effect on the kick time for resin? with this heat I'll need a fan in my boat just to keep working but I dont want to shoot myself in the foot by using one. Im sure I should catalize the resin at a lesser rate also due to the high temps here in Mich this weekend???
I dont know what you plan on doing with resin ( glassin or fillin ) .. but you dont need to be out in the heat like this right now.
Filling some cracks with Hair is fine .. actually its a good time to do some filling and fairing.
But for Lams .. actually layups of glass .. not a good idea to do it right now.
Its not the fan that will determine the working time of the pot of resin .. but the cure time of the surface. If your drained then all other things go to waste. ... You cant be Drained and expect a good lam schedule Unless your used to the heat and the Duration of such an expected Health implications of the process.
I suggest you take it easy until the Heat calms down a bit. ..
We as glass guys cant work in the cold .. nor can we work in High Heat if its a Lam or Grindout.
Hope this helps.
YD.
